I have Mehran 2004.. facing starting problems.. n also fuel average is high.. after 1 wk of last drive car is not starting... Sluf is okk.. battery also charged... Plz suggest some tips
Check the distributor if current is passing from there.
Less current coming from coil
If you’re sure than it’s time to change it, I didn’t think it cost much, it’s an easy fix, you can do it yourself.
Check the coil, by measuring the resistance using dm
