I'd been itching to change something on my car for a while now. Rims were too expensive, tires I'd already gotten... with GT-R style nitrogen!
So I decided to go for headlights. I wanted to stay away from HID's because only ***** - [Mod Edit] use them. **************************************** - [Mod Edit]. They blind you at the worst of times.
I got Sylvannia Silverstar Ultras. $29.99. Expensive? Yeah I'd say so...
Cleaning the headlamps. I had been told by a friend to try out toothpaste as a rubbing compound to see if that would make a difference. Decided to give it a shot.
Before:
The toothpaste spread on:
Spray on a bit of Windex:
The result: (it's not that apparent, but it's clean..er)
Now the installation process was a b*tch because I didn't have a double-jointed screw driver. SO, I had to take the battery out so I could get to a small screw. I didn't expect the battery to weight 3 and a half tonnes! and my back is still hurting!
The result-
Before:
Unfortunately you can't really see the difference in the day:
The real result is at night:
The one on the left is the 9005HB high beam (yellow halogen), and the right one is the new 4000K temperature bulb:
And that's about it!
Language please - [Mod Edit]
