Thanks for detailed ans bro
LIKE them
haha liked them all
Bro one other thing. My car is throwing water to bottle from radiator.. what should be the problem? T valve is removed as engine block and radiator is rusted
put t valve back ... wash the radiator with MOLY LIQUI radiator flush... If not solve it means some prolbem may with your car gasket
First get your rack fixed and once you are fully satisfied than install EPS.
EPS do not require change in rack but need rack in good condition.
Gaskit is fine and yeah ill will flush my radiator then ill put coolant and then will install T valve back. as Engine block is rusty so cannot risk with T valve.
Okay Thanks brother!
Bhai wasy 555 japan and geniun tie rod and rack set men just life ka difference hai ya working men BHi hai 555 as its is smooth kam kerta hai k nhe like genuin plz guide men ne tie rod change kerwana hai Civic men geniun 18 ka hai or 555 6 ka bohat diffrence hai soch raha 555 dalwa loune
Yes 555 is best in aftermarket steering parts. I use then from 2016 December still no rack and tie rod problem.. You can go to 555 works like genuine one...
