Alright guys, here is just a little teaser of my latest purchase. Which is something true audiophile Grade and a Limited Edition product by Focal. Guess what it is
The trophy goes to those guys who guessed it to be a Focal Power Series Amp.
Now for the Real Deal (H)
Here it is, I present you one of the finest SQ Audiophile grade amp.
The Focal Power FP 4.75 LE Limited Edition.
Specs:
- F Power Series Class A/B 4-Channel Car Amplifier
- RMS Power Rating:
- 4 ohms: 75 watts x 4 chan.
- 2 ohms: 100 watts x 4 chan.
- Bridged, 4 ohms: 200 watts x 2 chan.
- LED power and protection indicators
- Bridgeable operation
- Preamp RCA outputs
- Short circuit, DC, thermal, clip limiter, over-voltage, and reversed polarity protection circuitry
- Damping factor: >200
- SNR> 100db
- Slew Rate: >20V/uS
- Gold-plated RCA level inputs
- Gold-plated screw terminals
- Variable high-pass filter (50-150 Hz, 12 dB/octave)
- Variable low-pass filter (50-150 Hz, 12 dB/octave)
- Frequency response: 10-35000 Hz
- Dimensions: 13.8"L x 11.0"W x 2.0"H
More Details:
Focal Power Series Amplifiers
Focal FP-4.75 (fp475) - 4 Channel Amplifier | Four Channel Amp - Sonic Electronix
This is an underrated amp, since the output power has been measured at 13.8volts rather than the typical 14.4volts. More over the amp has been rated at THD+N < 0.03% rather than the typical THD+N =0.1%.
Other than this, things i like about this amp are
1. SNR > 100db
2. Slew rated >20V/uS. WOOW
3. Damping Factor >200 power with control
4. Toshiba transistors installed in this amp.
Now I wud let the pics do the talking
Hope you guys like my latest upgrade
Thankx for viewing
