Any body used this product? What's your reviews?
i ve used few times on my markx but u dont feel any difference in fuel consumption n also on performance....u shud try other products like liqui moly octane booster
Have you tried liqui moly octane booster? how was the result on that?
Yes i tried it on my CG125...Results were not amazing but yet noticeable...
Sent from my HTC One V using Tapatalk 2
not yet as its hard to find here...only using liqui moly fully synthetic engine oil n its working great
What is the procedure to use? What ratio of petrol and this thing should be used in cars?
Ive used a fuel system cleaner once in my Vitz and results were noticaable, Secondly i tried useing a injector cleaner the results were hardly noticable,
I heard somewhere that acetone can also boost octane? Had any one tried it.? And what was the result and price and availability of the acetone esp in pindi islamabad?
Sent from my GT-I9300 using Tapatalk 2
this is a useless product, better to get hi octane
I am selling whole range of STP including Octane booster, bought from U.A.E, check my thread for info.
Chinyoti could you elaborate, also which product? Also I read somewhere that if you use these cleaners the gunk gets into the engine and then you have to do another oil change? Is that true?
Im not sure what product, But i bought it from Optimum motor sports, Zamzama, fuel system cleaner, im not sure about where do the deposits go, but i think they get burned out of the cylincer.
Lol...ok Im not sure either. Just what i read somewhere. Maybe someone knowledgeable will answer
Wen using such products does people think wat is the exact octane requirment of their Car/bike engine Wat is being fed to them & wat thery are getting after mixing such products ? dont they think enhancing octane numbers to seek perfomance wud also requires tweaking on other sides like ignition timing etc as well?
Where to get Liqui moly Engine Oil in karachi ?
better to use the injector cleaner the white bottle from STP. It has better impact, ride becomes smoother and increased milage. i have used it in different cars and it works well.
i got it at the plaza motor at the phase 2 extension, its near khan motor. i heard u can get from khan motor or Zafcom phase 2
al hamd shop near mukka chowke ayesha manzil karachi.
