i dont know what to call it,heat up issue or abnormality of temperature needle
i got all heating issues resolved by getting all work done so no chance of it getting heat up
one day while back from rwp from ijp metro side,i thought em pressing race on incline,saw temp needle n it was crossing middle,opened plastic bottle,it had water till full top,drove very slow till home,next day checked water n there was very little less,tried flooring in few shifts of 3 4 5k,it reached half,stopped...it started coming down
if i drive by 2k shifts,nothing happens,today while i was going to blue area passing F9 park,i think it rose to 3k,so needle starting crossing middle,kept till 2k rpm,it came back down,while come back home,road was going uphill after signal,shifted at 3k twice, saw needle it was way past middle,drove slowly,it came back down,decided to go to same mechanic who did the work,shifted at 3k twice,it reached middle, stayed at 2k,it came back
now the mechanic checked,he opened radiator cap n to my surprise there was no pressure at all,not even a single drop of water came out of it,n even water wasnt less either,he said everything is fine
now comes the amusing n shocking part,i asked him to come wid me n see for himself,i passed through atleast 3 uphill roads,started from almost 0-20 speed,floored ranging from 3 till 5k, went from one sector to other n came back n needle didnt even moved from its position :S
dropped him back,hardly covered 3k, it started crossing middle :mad: curvy road came,n it came down
story of tonight comes now
was driving pretty slow,once i think gear down shifted but rpm stayed below 3k,needle reached middle,i got furious, shifted at 3k twice n it crossed middle,then came in cng line, kept car start , turned AC on, after a while it came back to its position,turned it off,gave race till 3-5k rpm's, it crossed middle, turned ac again n it came back down, did like this a few times, then it refused to come down even wid AC on,then i gave little race n it came back down,after that i changed blower speed from 1x to 5x n it crossed middle even wid AC on n wasnt coming down wid blower back to 1x n wid ac off as well,
then i just turned the car off, switched key to ignition without starting after 5min,n it was down to middle, checked after 5 more minutes, n it was down to original position, started car to check n it stayed at normal position,after keeping car off for like 20-30min, tried a little flooring of 2-3 shifts of 3-4k n needle stayed at normal position
now i dont know what is the issue n i tried going to mechanic n tried showing him as well as i mentioned but nothing happened infront of him,what could be the issue? even when mechanic says everything is fine,what can i do on my own, i dont open radiator cap myself since i tried once even maintaining some distance widout taking precautions n water shot up very high where as those mechanics just keep a finger at middle n open it up
