made a long post at 2:15am on 20th march,forgot to copy the post, was going to add pics n it froze as site was down, had to write up all of it again :mad: might have missed something or not but was very annoying to write all of it again
before i used to copy post b4 submitting it but now i got a lesson of saving b4 adding pics too
went to akash today [yesterday],told him about all the work done....even though while going there needle was its level, but he said ur car is heating up, told me to touch plastic bottle n water was boiling there, after a while he opened radiator cap but there was no pressure there.
then he removed air filter thing n other thing n checked different stuff.
at one point he said radiator is blocked but didnt mentioned that again n even i forgot about it...then he showed me that thermostat valve is broken n it wasnt working,even though fan was working but water wasnt going to the engine as valve wasnt opening , also he cleaned thermostat swtich n applied silicon to rubber thing n attached it back there, took temperature sensor inside shop n cleaned that on some machine,after that tried flooring in that small street, felt fine.
there's no valve now,he said there's no issue as water is circulating freely now.
checked car on my way back by 3-4k shifts sometimes n on uphills, so far going well n needle not moving at all
addition: checked today as well till 5k shifts, MASHALLAH no issues
ab pta chalta hai k civic hi hai
finally those flooring days are back, car feels so speedy now lol but not pushing it just for the sake of that, tried one km wid ac as well but then max rpm would be 2-3k, last year after ac service, cooling was so great which started reducing, now its just so so again :S
brake goes down while applying,i noticed that long ago but got used to it,he noticed that n told me,also pointed out a sound that i used to hear on applying brakes like a whistle,he said thats due to the brake discs, he said these arent good ones n get them changed,for brake going down he said they need bleeding, i remember once i asked for it at nazir autos n insisted as well but they said brakes dont need bleeding,u just top up oil.
also he said steering oil is leaking,i couldnt see it dripping but he showed oil on his hand by touching it under there,he said it needs seals
so heat up issue resolved n this came up
2450 for front brake discs, 1700 for back of some brand nixon
2 bottles of brake oil required wid 325rs each
also he said tunning is required as there's alot of carbon in butterfly thing "carburetor"
so almost 8-10k work came out
i asked him about radiator cap, he said this is fine, its working fine, u dont need to change it, asked for 500rs as labour :o
@fahadwizz @d_sha @hash4u
