In order to take out old boots they would have unlocked complete axle. They dismantle inner cv joint with the help of hammer. Now that's malpractice, and hammer bends up that tripod bearing inside the cv joint. It's on the dealership, if the work was performed recently then you can go and claim it. Tell them that you guys have bent tripod bearing by hammering it out, and now I have vibrations (claim it) my axle is ruined by you guys. Other problems are related to that as well because your cv joints are loose now.
That's normal in k313 cvt, the ecu keeps on thinking for a while that you need more power and keeps the rpm high for a while, it will drop back to normal within 5 seconds once you start driving economically.
Because your cv joints were not hammered out.
In order to change boots hammer on cv joint to dismantle it is the best malpractice in Pakistan. You can change complete cv joint or just a tripod bearing if you're able to find it somehow.
Everyone will say that it's a problem of gear, but nope. Been there and resolved that issue after banging my head here and there.
