Dear All,
i am facing a strange issue related to RPM in my cultus carby 2003. Thermostat valve is installed with auto-fan for radiator
On cold startup, autochoke engages and RPM comes back to normal but only for petrol. for CNG, RPM remains between 1.5 to 2. I have tried to adjust the idle RPM through the knob on CNG kit which is used for idle setup but settings goes away after the drive of few KMs.
if I start the car without pressing clutch the RPM stays at 1 but after some drive, it increases between 1.5 to 2 and if i start car with pressed clutch, it start at 1.5 even though car is heated-up enough
Strange is if i reduce rpm through kit knob at this point, and reduce to 1 then after some drive, RPM doesn't remain at 1 but goes to 0.6 - 0.2 and engine starts to stall and i need to maintain rpm at 1 by pressing race paddle else it will shutdown. (A)
