RPM needle is behaving like hell it going up and down frequently without any increase in acceleration happening with both AC or without. Had CNG installed.
Had same issue, just sprayed WD40 on clutch and race wire. My issue resolved. You may also try. It may heLp.
Have tried almost everything but nothing is working I think there is some wiring issue. Have decided to get it scanned.
Cultus's ecu is veryyy dumb. It forgets everythig with this process
Did you clean the Idle Air control valve (IAC)?
Tried everything which you guys suggested but no successCan anyone confirm if go for computerized scanning will this help me because I got no check engine light with this problem.
I have the same problam in my cultus 2007 efi ,it is Throttle body problem ,it can solve by cleaning it by mechanic ,
