Maggi Help me
Is amplifer use to match Prevolts by amplifer input voltage sensivity
i have read in bcae that if amplifer sensivity is lower then prevolts , clippng will start
amplifer sensivity voltage should be higher then prevolts to avoid clipping
gain starts from higher voltage to lower like 7 volts to 0.2
each amplifier have difference initial and final voltage points
lets suppose my pre volts on Sub rca is 2.2 volts
at i turnup the gain , sonsivity of voltage will decrease
like 6v to 0.3 v ,
if the gain sensivity get 2.2 , accurate to prevolts ,my amplifer will produce max watts
if my pre volts is 2.2 and i turn up gain seting , lowering volts , less than Input RCA pre volts 2.2 , clipping will starts
if i set to max gain , clipping will destroy my sub , or it can overheat the voice coil , may blow my sub`s coil
am i right ?
