@Xulfiqar , @incognito59 , @sunhonbun , @sjehsan , @ronz2202 , @uzi602 , @StrikerX , @Ravager , @sheikh_wah , @FarhanAnwarKhan , @qwertypoiu , @Marwanpasha , @asdalix , @uzi602 , @umer325 , @a1ms , @ahmad_yar , @Durrani_45 , @GoodMan7
Hi guys, I've got two cars and they are both due for service so I'll provide some information about my cars so that you guys can suggest the best possible products for them.
1) Toyota Corolla GLi 1300CC Manual, 2010 Model
Currently 45K on ODO and last service done on 40K by Toyota Garden Motors including these things which were suggested by you guys since I didn't want to go with full 40K service which was very expensive:
Toyota Motor Oil ( Petron API SL / CF ) SAE 20W50 4 Litres = 1916Rs
Air Filter ( Sankei purchased from Filter House ) = 750Rs
Oil Filter ( Union Japan purchased from Filter House ) = 490Rs
Changed all four spark plugs ( Toyota Genuine ) = 1480Rs
Brake Service = 600Rs
Engine Tune Up = 600Rs
Throttle Body Service = 1200Rs
Injector Service = 2500Rs
Now 5K has since passed and it's time for the regular service. This car hardly gets used, it did 5K in almost 6 months and most of the time it's parked in the garage and I just drive it after a few days within city mostly.
Kindly recommend the following things:
1) Best Oil for my car according to current weather, should I stick to same TMO???
2) Best Oil Filter which is economical but will perform good until next service, are guard filters good enough???
Also do I need to replace the Air Filter as I think I read that it should be good for 10K???
2) Suzuki Mehran VX, 2008 Model
Currently 110K on ODO and last service done a few months back by my dad from some local mechanic so no idea what's in it right now. This car gets used a lot and I've seen some oil spots on the floor underneath the hood so definitely some kind of leak.
So need your suggestions on the following things:
2) Best Oil Filter which is economical but will perform good until next service, will guard filter suffice???
Also do I need to replace the Air Filter in this car, will guard filter suffice???
I know it's a long post but wanted to make sure you experts have all the required info before posting your suggestions
Thanks in advance!
