My mehran headlights lacks focus on road. Light is scattered in all directions in low and high beams. I can't see anything on road at night. Also on coming drivers suffers due to my car headlights. Please suggest me any solution.
Find a good electrician. Plus put some high intensity 4000k philips hids or halogen in low beam. You will never regret it.
Oh mehran has only one bulb having hi-lo beam. Buy philips only with warranty or something.
I need focus. I am thinking of installing 2 extra spot focus lights and stop using headlights. Installing Philip bulb is not a solution as current bulbs are quite good but light is traveling here and there. Suggest some after market spot lights
Don’t know after market things. These headlights look good because you my brother havent experienced philips HIDs. U wanna put high intensity lights in fog light compartment? I think the beam isnt that big or good. I’d try the low beam hids as they are the ones i am gonna use most of the time. Philips says descriptions of each bulb on their product cases. Such as some bulbs are 110% brighter than normal.
How about this 6 inch 18 watt spot beam installed on bumper while use stock lights only in dim light mode.
Bump
Go for a bixenon retrofit.
Checked a bi xenon but light output was low.
check wiring connections and adjuster....electrician will fix it...
i faced this issue....connections were wrong....was easily fixed..
Suggest a powerful bi xenon. Upto what watt I can go which should not cause harm to battery or other things. What if I use stock lights plus powerful bi xenon at same time.
I don't get it? What are you saying and what exactly do you want? Which bixenon setup did you check ? Please enlighten me?
I don't want to modify stock lights instead I want to install powerful bi xenon on bumper.
Do you even know what bi xenons are mate? It's ok if you don't, you just have to tell me so that i can tell you what they are
I have a little knowledge but please do tell me more.
There are adjuster screws on the bacl of your headlights. Adjust em yourself or pay a mechamic to do it (rs 200). Watch ChrisFix's youtube video on how to align headlights
I have already done that. No good. I will search for projector thing.
Go for COB type leds and import them from china. Local market in Pakistan does not have quality leds and their prices are also on higher side
which model you have?? no need for any HID type thing and waste your money.. if your car is too old you may have to buy new headlights.. i dont know condition of your headlights.. if yiur car- is new and only focus problem you need to check its alignment. thats all.. side by side and up down alignment need yo be checked.. do it your self by using meter tape and a straight wall..its easy ..
I'll recommend you to retrofit projectors and install HID's in them. You won't regret it.
