This is the special model of ferrari only one in the world specially made for sultan of brunei.The specifications of this car are as follows
engine F110 HB Flat-12 w/Custom Exhaust
position Mid Longitudinal
aspiration Natural
valvetrain DOHC 4 Valves / Cyl
fuel feed Bosch K-Jetronic Fuel injection
displacement 4943 cc / 301.6 cu in
bore 82.0 mm / 3.23 in
stroke 78 mm / 3.07 in
compression 10.4:1
power 328.1 kw / 440 bhp @ 6750 rpm
torque 500 nm / 368.8 ft lbs @ 5500 rpm
drive wheels RWD
body / frame Carbon Fiber & Aluminum Body on Steel Tube Chassis
front brakes Cross Drilled & Vented Discs w/ABS
rear brakes Cross Drilled & Vented Discs w/ABS
front tire size F 235/40ZR-18
rear tire size R 295/35ZR-18
steering Rack & Pinion
f suspension Double Wishbones w/Coil Springs, Koni Dampers
r suspension Double Wishbones w/Coil Springs, Koni Dampers
transmission Williams 7-Speed Sequential
