You need to chk your tempreature guage before doing any thing. Folow these steps.
Step 1
Unplug the temperature gauge from the sending unit. This is usually located to the right of the engine.
Step 2
Turn the ignition key to the "On" position. Do not start the car.
Step 3
Ground the temperature gauge wire to the engine. You should use jumper wires to ground the temperature gauge.
Step 4
Check the temperature gauge inside the car. The reading should be in the middle between hot and cold.
Step 5
Turn the ignition key to the "Off" position.
Step 6
Check the fuses inside the car. If the fuse connected to the temperature gauge is burned out you should replace it.
Step 7
Ground the jumper wire connected to the sending unit terminal located next to the engine.
Step 8
Check the temperature gauge inside the car. If the temperature now reads hot, then there is a open wire in the sending unit. You should immediately have the temperature gauge repaired.
