RWat about this one!
You can see a huge bunch of beast on this thread also:
https://www.pakwheels.com/forums/cool-classic-cars-latest/157882-some-really-cool-powerful-beasts-pics
950BHP,2.2 BAR BOOST,8.27 SECOND QuaRtermile.
Engine Specs
HKS Hi-Deck Racing Block, HKS forged pistons, HKS billet conrods, HKS billet crankshaft, HKS drag Camshafts (undisc), HKS drag headgasket (undisc), HKS valve/head system, HKS main and rod bearings, HKS head bolts, HKS machined cylinder head, HKS oil pump, HKS 1000cc fuel injectors, HKS billet fuel rail, HKS plenum gasket, HKS exhaust gaskets, HKS T51R SPL BB single turbo, HKS exhaust manifold, HKS racing wastegate, HKS racing blow off valve, HKS intercooler piping kit, HKS GT type intercooler, HKS cam pulleys, HKS Kevlar timing belt ( Hi-Deck version), HKS twin power ignition amplifier, HKS billet oil cap, HKS racing turbo suction, funnel, Do-Luck ignition system, Hyper Direct Coils, JUN intake gaskets, JUN inlet plenum, Naprec 100mm throttle body, Nismo waterpump, Nismo water thermostat, Pitwork oil filter, Trust large capacity oil pan, Sard fuel pressure regulator, Earls fuel lines & fittings, ATI crank damper and pulleys, Modified camshaft covers, Hauser racing radiator & pipework, Hauser racing swirl tank and header pots, Hauser breather catch tank & filter, Hauser side exit exhaust system, Pacet electric water fans (2x), Aeromotive 2000bhp fuel pump & filters, Racing fuel cell, Castrol EDGE 10-40 engine oil, Castrol engine coolant
Drivetrain Specs
HKS 5 speed airshifted gearbox/HKS H pattern 6 speed dog gearbox (backup), Sumo heavily modified 4WD transfer case, HKS drag driveshafts front and rear, HKS triple plate clutch & flywheel, HKS Hipermax Drag suspension & custom spring rates, Cusco 1.5way LSD front diff, Cusco 2way LSD rear diff, CTG Torqline carbon propshaft, Wilwood lightweight 4 pot brakes (x4), Sumo heavily modified front subframe, Sumo front anti-rollbar (undisc), JUN rear drag subframe, Do-Luck rear diff mounts, Do-Luck suspension bushes, Do-Luck subframe locking kit, Nismo subframe bushes, Cusco anti-hicas lock kit, Cusco camber adjusters, Cusco traction rods, Ikeya Formula front traction rods, Trust front diff extension plate, Hauser main propshaft safety loop, Hauser welded engine mounts
iNTERIOR sPECS
AAR racing seat FIA approved, Teamtech 6 point racing harness FIA approved, Hauser racing multipoint weld-in cage ( 7.5sec spec FIA), Sumo carbon fibre dash, Lifeline fire extinguisher system, Do-Luck Boost gauge, Cartek electronic battery isolator, HKS shift knob, HKS FCon V Pro 3.2 ECU & loom, HKS EVC5 boost controller, HKS airshifter control box, HKS airshifter solenoid bank, HKS airshifter gas bottle & regulator, HKS mixture controller, HKS trigger button, Hauser control switch panel, Varley Redtop battery, Custom wiring loom/electrical system, Custom 4WD system, Linelock, Wilwood pedals ( brake & clutch ), Hauser throttle pedal, Lambretta throttle cable, Sparco Steering wheel, Sparco quick release steering boss, Deist parachute lever, Hauser Aero window catches, OMP window net, AutoMeter 4WD gauge.
