I have a super power 125 deluxe a mechanic told me to install cg carb to get performance better but then i noticed that the classic 125 meter says the max rpm is 10k and the deluxe have 11k rpm so if I install a cg classic carb does the carb would give the engine fuel reqiured to have 11k rpm aur I have to find deluxe carb
what do u want to do with 11k rpm?? ride safe bro..
U have to change plug to deluxe dp9xxx as well stater coil, ignition, inner coil, outer coil, min coil all of deluxe then pressure plate clutch plate of original deluxe then u may reach 11k rpm
Sent from my iPhone using Tapatalk
Most important CDI Unit from deluxe, u have alter the wiring then it will be installed...
What if we want to increase the rpm of deluxe should we install cg classic old model cdi to get better rpm ??
