AGS will not change gears smoothly like a normal / CVT gear if you keep the accelerator pressed. The formula for AGS gear is, that you need to lift your foot from the accelerator when you want the car to change gear. Once the gear shifts, press on the accelerator again. You should not feel a jerk this way.
However, I am not sure, why your car is shifting to neural automatically.
