Salam,
I have a 2017 alto Ene charge full option CVT gear. Current meter reading is at 163k kms with genuine assembly. I have driven the car for about 13k kms and I ran greatly until recently. Following are the issue that I am facing. Car is giving no check light and no codes on scanner.
- Car jerks severely when accentuating hard above 60, but only on accelerating. It gets smooth when causing on hughs speed.
Sometimes When taking a u turn Car will get stuck. Means when I release brake and press throttle nothing happens. Car will move at about speed of 5 but no response to throttle no rpms changing. Then I change from D to N and back to D then It moves with a jerk.
Some times while while cruising at 20 or 40 Car will jerk with rpms fluctuating.
I have done following things
1. Plugs changed
2. Coils changed
3. Gear oil changed
4. Then gear also changed still same issue
5. Throttle body, MAP sensor, Mass airflow sensor.
All parts have been changed with kabli parts and the issue persists. Location is gujranwala. Plz do help what u think is the issue.
