Replace it immediately
Repacle is asap as it can cause car to overheat.
Hey guys. I'd like to get a price check from you guys about a white alto, khi registered, 2010 model and reg, has a few scratches in the front n back bumper, under 45k mileage. demand is 7.50 lacs.
add me bro...i have got some more stuff to share 0346-9122399
Can someone recommend me workshop in Lahore to pressure test cooling system. My car is reducing water after radiator service(about 250ml in every 500km) and there is no apparent leak. I want to properly test the system to identify the leak before adding coolant.
Was it over heating
No reducing about 200ml water after 300 km. Seems like a small leak which opens at high pressure only. Visited 2 so called Suzuki 3S dealers and they don't have equipment to pressure test the radiator. They want to follow traditional method of changing parts one by one until problem resolved. Now i decided to change the radiator and Fan as advised by my mechanic because it seems choked. Hopefully that will solve the problem otherwise i have to look for heater core for any potential leak.
I have alto 2011. I want to to install EPS. Can anyone tell me of a reliable place in Bilal Gunj to get it installed and price. Also any details to keep in mind while installation? Any help would be appreciated.
Let me know what was the solution I am having same issue in Civic apparently no leak..
Sent from my ONE E1001 using Tapatalk
Shall I go for a Engine rebuilt or new engine. Need cost comparison. My alto engine has gone as it was driven by my Dad while I was out of country. In terms of new engine what are possible options??
What is issue woth current engine l?For swapK10b is bolt on alto
Reducing Oil, Thick Black smoke. havent seen the engine myself but friends say that. Ring piston gone.
K10b price including everything with installation?? And available in karachi??
heater core is most of the time culpirt as being napak suzuki product heater core is build with very low quality 90% altos over heat due to bad heater core use coolant only in this cariron block engine plus water is rust and clogging in cooling system and it will choke means car will over heat
rebuild with genuine parts will cost u same as the swap but with more hassle and most rebuilds on f10a no matter how good mechanic is it will last most 2 years then again he will say Sir 660 dal lein so thing is with high price of engine parts of F10a its better to swaphere are ur options for bolt on swaps 1 K6a (660cc) 2 K10A (just add one more cylnder to k6a )3 m13/M16A (people say fuel eco is bad but thing is big engine small body heaps of power mostly it will be in high gear at low rpm making economy good)4 G13/G15a (balneo engine with very little alteration )so choice is urs
K10B is 3cyl comming in pkdm WR its karimun Malaysian engine not available used K10A 4 cyl similar output to k10b bolt on swap for alto price in shoba peshawar was 43k with auto gear and 45 with manual
price may vary form 4500 to 6k and installation will cost 1k just make sure installer connected speed sensor with eps wiringusing eps in my 2011 alto since 2014 no issue
bro pm me ur no
sent you my numberregards
going to sale my Alto planning to buy FAW v2. Need Advise....
