Agreed.Solar Screen tints are worth every penny.
Thanks, might go fot it, have talked to solarscreen guys.
One more question, do you guys have metal one or ceramic one?
Z8 mettalic
Thanks, does it disturb signals?
Hello, I have the VX variant hence no company fitted ac. I had it installed separately and it works just as well. What my ac guy did to "improve cooling" was remove the connection to the heater (which I loved during cold mornings!) I was wondering if this car has a regulator of sorts to stop the hot coolant from flowing through the heater core? As Suzukis older vehicles like the cultus dont, coolant tends to flow in the heater core regardless.
No but interferes with mtag
When I shift gear to manual it stops and on the dashboard it reads neutral and from their it locks itself and also when driving in automatic it keeps on shifting to neutral.what is the real cause??suzuki alto 2017 model
If anyones interested in the factory VXL headunit, I've replaced it with a pioneer Z series so it's just sitting in the closet. Almost new with no imperfections. Dirt cheap (SOLD)
Pioneer Z series.......is it android?
Can u share pics.
Running the Z5250bt which has carplay and AA. Was previously running the Z2000bt which only had carplay
mention price and location plz
4k. Islamabad
ok done, i wil send u a private message for further
Today I faced a problem in my alto vxl . Basically I went to the market which takes me around 40 minutes . I turned the ac also and parked car here for almost 30 minutes . As I was sitting in the car , so the ac is also turned on . But when i start to move the red indicator starts to blink on meter , after that I turned the ac off and light goes away. Kindly guide me about this issue
can overfilling in reservoir be cause?
Hows the performance of Honda Life Compressor for Alto VX specifically regarding the Load on the Engine,Fuel average and cooling performance and how Much Should the setup cost,I was qouted 75K for the AC system
And Has Anyone Swapped PKDM Alto with Engine from ALto works 660cc turbo engine Whats the Review is it worth it and How much does this Swap cost?
I have upgrade my tyre size to 165 70 r13. What tyre pressure need to maintain on this. Opinions required who has upgraded to this size
i installed the same setup in my new VX. ac was extremely chill - alot depends upon other ac parts + refrigerant (gas) as well. my honda life compressor had a small humming sound on acceleration and as per ac wala it was normal. it was irritating though but i did'nt force much as the ac was super duper chill even in peak karachi weather. worked super fine till 46k kms/2.5years till i sold the vehicle.
Any one please help
