Thanks it solved my issue i adjusted both idle butterfly screw and ac one with spring . Keeping idle at 800-900 and witch ac at 1000.
Now my issues is when i drive the car in this setting for like an hour when it heats up the idle rpm reaches at around 1100 with ac and 1000 without AC.
is there a better way to fine tune this?
Should i do thhis while car is heated up?
Also any brother can share the vaccume pipes pictures the origal settings. Currently i can see only 1 switch of vaccume for Ac only i have seen multiple video where vultus and alto have 2 vaccume switches. I dont know if that is removed by previous owner.
