1-Autobox with Axles, mount wiring and ECU
2-Gear lever console complete with control cables.
3-Pedal set
4-Speedometer
5-Ignition switch if u want that key wont come out unless u shift in park.
6-radiator, as for autobox u need radiator with cooling lines for auto txn.
as suggested above, its better to do a nosecut swap from a donor car, it will be hassel free and cost effective to, as u wont be needing to hunt for each and every part separately, and might get benefit of installing ABS unit as well as
