Assalam o Alaikum Pak Wheelers,
This post is about Suzuki Baleno 1.3
Yesterday my car suddenly Started a lot of missing for no reason (identified later on).
1) First me and my mechanic visited electrition to see if there’s amy sensor issue
2) He said the issue was with the injector grips we changed all the grips with Kabuli costed 800 in total but the problem wasn’t solved
3) Then he said the injector is faulty, by removing the one coil wire the car didn’t lower the power
4) As one of the cylinder no 1 wasn’t working by removing the coil wires they checked
5) He then replaced all the injectors but still none of the problem was solved and at last he said to check the valve seal
6) Than we return to Workshop and my mechanic open the plug of Cylinder no 1 and put some engine oil in that
7) We started the car and it gives a lot of white smoke and issue was resolved instantly Alhamdulillah
Mechanic Name is Irfan Sitting Zia Autos, tipu road, opposite to Go petrol Pump ATM
