Hello!
I bought SUZUKI CULTUS 2007 EFI 2 month ago, I didn't checked the car because i was so much busy until I paid for it because I thought that i know this person he'll not make me a bad deal so got me a deal for this car like in Almost 6,00,000 RS and I paid. He told me that this car needs engine overhaul and require some work on passenger side "hissa" and i said ok no problem. we'll do the required works. But when I got the car it was not in very good condition. I felt that this car is completely repainted badly and is almost full of poteen.
Anyways because I had already pad for it so I thought its ok now. Later I went to the market for machinal work of my engine in Islamabad the mechanic told me that passenger side "hissa" is completely damaged and the "Goda" and other stuff are just hanging, so now first you have to go to some denter wo can fix this so i went to 7 brothers (a well known denter in Islamabad) and saw the car from far away maybe from 2/300 meter and he said from where you bought this car? i asked why? he said this is totally damaged and completely builded. he haven't seen this car earlier but he said this on his experience. He said i will even 1% recommend you to waste money on this. So you should sell this car asap. He said you should sell it within a week. Although i could not seen these things but later on every point i found out that he said 100% right things
Well i asked him to do the work for "hissa", later i wented to some other denter and painter and completely rebuilded the car which included,
New floors
side panels
golaaiyan
doors fixing and almost everything when seems bad, i made complete denting and painting and some mechinal works of "Goday, Kanghi, wheel alignment and some other stuff like this" which costed me almost 2,00,000 Rs.
later i went to electrician, he said ECU in this car is some japanese car's ECU and no sensors are working, everything is direct.
Now i am very confused. I wasted my so hard earned money and getting nothing.no the condition of car is
Tires are almost ended
Engine is in bad condition. it is making the Engine oil level low again and again and one plug is not working properly.
RPM body is not functioning properly (When i start the cold car, RPM is very low, like ignition is about to stop. after car gets some warn, the RPMs are 2000)
Wiring is almost direct. But lights, indicators, ignitions working fine.
The paint again started to getting off, Rust is again coming on parts,
I am using the car daily now,
Sometimes it's not taking the self like nothing happened, after sometime it takes the self..
Its is giving me Petrol average of 3/4 KM per Liter
Door locks are nor working properly.
I am literally so much messed up that i do not know what to do as i first time purchased a used thing and not know any good mechanic or something like that...Also i need to car because it is the only convaince for me these days. I literally wasted so much money but got nothing. Now i am literally confused what should i do?
Should i go for the other works on this cars?? or i should sell it..?
and if i sold it what will be the next option for me in that range. Although look wise its now in good condition.. but these other problems..
Someone please suggest me what should i do? and what are the options?
