check with a good electrician who can check if ECU is sending signal to sensor, if yes, then sensor is faulty, if no signal to sensor, then ecu is faulty or maybe faulty fuse in the fusebox. check these things.
t-valve na bhi gari main tab bhi agar engine overheat ho to fan on hona chahiye
lekin ap t valve or temp switch pehle hi change karwa chukay hain to check karwain k switch tak signal kyon nahi pohanch raha
