from where to buy this can in rawalpindi.And how to get it filled in the AC system and whats the price.Is it of good quality .
leave all the tints,blinds etc...get this solar ventillator...it works just fine and u will be amazed i got 2 of these
Car Ventilation Fan in Pakistan
yes u r r8,the efi cultus has a valve which removes the gas when the car gets hot,...i had the same problem many times but nw a little care is all it needs
i am hearing this for the first time.
Yes man thats work for the main reason of A/C's bad permance or you can say that late performance is just because of hot dash board and its hot like garam Tawa so if i keep egg with me in the car so i can easily half fry the egg LOL that for fun.Now com to the point so one day i decided to put shade on dashboard to know the real reason of A/c performance i put the shade on dah and park my car in direct contact of sun so after 6 hours continous hitting of sun on car when i come and chek the dash and the dash was normally hot i can easily put hand on it then i turned on the car A/C and its work 10x better than before and you know i got really shock to feel the different and got the reason why A/c had bad performance it is just because of hotness of dash.
thank you for your advise man i got the solution for my problem in just 500 rupees got gud quality dash board shade and drag down the all 4 windows half inches instead of waisting 1600 on ventilation fan. and its 100 % work for me
You are talking about the overpressure relief valve - it only opens when the high side pressure spikes to dangerous level, usually not seen unless you have a failure like fan not working.
Glad that it worked for you, Reflector is good to save dashboard from UV rays too, UV rays can make your dashboard dull in long run and keeping window down a bit will save car getting Oven effect which causes car to overheat in summers.
from where i bought this ?
Cabin filter to Cultus main aata hi nahi, or agar install kerna ho to kese install hoga, like Corolla mein to iska compartment bana hota hai. how to do it in Cultus.
You can't
