My Cultus had a rusty cooling system and was losing water, so I replaced all pipes and installed a new radiator. I flushed the system and added Addinol coolant mixed with water. Now, there are bubbles in the radiator. I’m using 5W30 engine oil, and there is no reduction.
Jameel Autos in Karachi, recommended by PakWheelers, said to continue using it if it's not overheating. They diagnosed a head gasket leak.
Problems:
1. The car loses water from the coolant bottle, requiring weekly refills.
2. The car misfires during cold starts, especially in first and second gear.
Note: There is no oil-water mix in the engine or radiator.
What should I do?
Irshad Bhai from Jameel Autos quoted 10,000 PKR labor for replacing the head gasket, excluding parts and head resurfacing. They suggested a cardboard gasket instead of steel, but I’m unsure which is OEM as the engine has never been opened. Another mechanic at Jameel Autos said cardboard gaskets settle better if there's an uneven surface.
Can you recommend a skilled mechanic in Karachi with proper tools and knowledge? Which head gasket is best, cardboard or steel? Are OEM head bolts available for Cultus, or are aftermarket ones just as good? What other things should I focus on?
