Hello Everyone,
Need some help hereTrying to connect a 12V accessory in my cultus(new model). Plan was to use fuse tap on radio fuse. I opened the fuse box cover, there is description of all the fuses on cover back side including radio fuse but can't find the actual fuse. Can anybody guide me on where the fuse for radio or power socket actually is in new cultus??
radio 2 as mentioned on printed box
in the fuse slots i can see non designated fuses inserted contrary to printed nomenclature
Radio 2 is printed on the box but there is no such fuse in actual. Neither the fuse nor the slot
ACC2 and radio2 both are missing
All other fuses are as designated on box cover
now the only way to identify radio fuse is to switch on radio tune to any channel turn volume up, remove each fuse from slot 1 by 1 and identify the radio fuse.
It's not that the fuses are misplaced but two fuses are missing
There should have been 22 fuses, as per diagramBut there are only 20 fuses
these are not missing. , under that it is written for LHD means both fuse position for LHD vehicles.
in a LHD vehicle ACC1 & Radio 2 will be absent. which have RHD marked.
Suzuki Cultus 2014 fuze cover
It's hard to find on Google Just sharing
Bro can you tell where is radio fuse of cultus 2013
Does someone know if there's a fuse for third break light for new cultus model, its also known as High Mounted Stop Light. Thanks.
Hi, can anyone tell me where is the radio fuse on 2020 cultus ags? I opened the fuse box next to the battery but it doesn't have radio2 like the one shared above. Infact there isn't any matching radio.
Where to fine cigarette lighter fuse in cultus 2006?
