In this video I showed you guys how to do front brake service of Suzuki Cultus/Celerio at home easily. The tools and products I showed in this video are easily available in market at reasonable prices so everyone can do this at home. Brake service increases brake pads life and braking performance. If the caliper pins are not properly greased the brake pads will wear uneven and fast, the brake caliper pins will also get damaged. So always do the brake service after 40k kms. And avoid using Lathe machine on Discs as it decreases the thickness of Disc.
