So when the door is not closed properly and the car is moving it will beep same is with the handbrake
Hi, i'm planning to buy cultus VXR through alfalah bank. I was going for wagon R VXL before but with it's price increase recently now there is just 1 lac difference between them. I wanted to ask should i go for cultusVXR? It has more features and spacious and comfortable than wagon R.
One thing also needs to be clear whether cultus has good resale value comparing to wagon R or not within a period of 1 to 3 years.
offcourse go for Cultus...
Resale is not an issue as i will keep the car for a long time IA. Other than that i think cultus VXR will be a better option than wagon R VXL as the car will be on lease and there will not be much differnce on installments of both.
Thanks for the suggestion. I also wanted to ask if there are any issues in new cultus as i've seen some people facing some issues. I want to be sure as road conditions in rahimyar khan are not very good and i'm afraid whether the parts will be easily availible or not..
Cultus have some issues better to go for wagon r as the later has little or no issue.
Cultus is better more comfortable,better pick and millage..features wise cultus have four power windows but missing alloyrims chrome garnish and silver trims in interior..
I have used it, during first 300km it valve seal leaked, but after that is used it for more than 22k kms and it was good.
Thanks for the suggestions everyone.
Go for cultus. WagonR na shakal na matha. Rickshaw like.
Ur ac water drain pipe maybe leaked or choked.
Hi to All, I have Cultus 2008 Model, i am facing a problem of heat up. its temperature is almost at half but sometimes it goes bit higher than half and the water goes like boiling in side bottle. The level of radiator water is normal, Fan is auto, no leakage in Radiater.
Any one please guide me??
Yes A.C pipe was choked
Radiator is choked , it needs cleaning .
i was facing similar kind issue in Alto VXR few months ago, problem is leaked heater coil, due to this car is over heat and radiator giving problem so i opt for radiator replacement and after that i face no issue,,,,,,
Get radiator serviced / cleaned, look for any leaks. If the problem still persists, change the fan to a better one for more air flow through the condenser.
What should be pressure in all four tires? I mean front and rear?
for cultus, PakSuzuki recommends 35 for front and 33 for rear,, more precise, according to load.driver door p mentioned h complete details
As mentioned above, check the driver's door for the factory spec pressure. And as a precaution, don't fill upto factory spec pressure on stock tyres. Only fill to that pressure if the tyres are not stock, and have the capacity of at least 40+ PSI. It can be a safety hazard, especially on high speeds. If you have stock tyres, I would personally recommend nothing above 32 PSI.
