@bujha
Bhai, check your Cylinder capacity in Litre. I have learnt from same pakwheels that Formula is:
Capacity in Litres X 0.18 = Maximum amount of Gas in Kg that can be filled at 200 psi
for example if you have 50 Litre cylinder installed then it will be:
50 L X 0.18 = 9.0 Kg
55 L X 0.18 = 9.9 Kg
60 L X 0.18 = 10.8 Kg
Mine is 55 Kg so maximum gas i have accumulated was 9.2 Kg(at that time 2 factors to be considered: My cng cylinder is not serviced so some oil must be there + Pressure was not 200 psi so they also disturb exact readings)
@RehanBhatti @abid110
Yes, role of wiring in EFi Cars also seems some impact on mileage performance. This is told by @sadatmasood11 bhai on some other threads and posts(Santro related) so @abid110 bhai check from this perspective too.
@sharoz.akhter
As your one is 2012 so as a special suggestion, never run your car in Petrol tank filled less than half Petrol(Even if u running it on CNG)
Your readings on petrol are very very good as i have mentioned; mine is giving 15.5-16 Km per Kg of CNG but on petrol, my average is very bad i.e. hardly 9-10 Km per Litre(if i travel on Share Faisal in open light traffic & in crowdy traffic, it is giving 5.5-6 Km per Litre(without A/C)
