Abid bhai, issue hai kia? Is it due to valve seals?.I can keep driving as it is....bas later on ye gradually barh kr koi major expense na aye.....I can go FB area...pls let me know shop and guy name....i will discuss with my father then go
yar seal ka he masla hai aur sab cultus me aata hai - as far as i have seen. fir tasalli, have it checked but masla jab solve hoga jab mechanic k samnay wohi problem aye warna trial and error per pata nahi kya kya khul jaega aur asal masla wahin rahay ga. if you are sure k aapka masla usi k samnay bhi show hoga then go for it
Theek. Understood.
Need expert opinion for my Cultus Euro II model 2013 clocked 30000km. It has been standing since 1.5 years. Its oil has turned thick. What do you guys suggest. Should I get it flushed, if yes then from where? Which engine oil should I use next Zic x7000 or SGO Premium?
No one
Which grade engine oil you are using in it?
Zic high flow
It can be feel on both cng and petrol but on cng is louder then petrol its start when engine become hot on cool (morning) no sound on both
Can anyone tell me the cost of heat insulation in old cultus?And If I insulate the wall between engine bay and room, will it make difference in temperature and working of AC?
No matter what you do, Cultus's ac is only good when Sun is not up.
need suggestionsCultus 2006engine is weak. could not use the a/c as well.mechanic suggests for second overhaul.(1st overhaul was done about 4,5 years ago)
How often do i check the disptick to see if there is oil reduction??
What if oil is reducing...but slowly...without any loss of coolant.....however, now there is no smoke in start up since 4 days ago.
Overhaul is the option as Cultus's engine is very expensive and rare in market (if thinking about swap)
Well i myself do not check oil regulaly but at time of oil change that what quantity came out.
Change its ceiling with 2012 model cultus euro2 if possible. If you have denso system intalled from factory then replace its single flow condenser with multiflow one (I will recommend city 2005 condenser). Install a puller fan for condenser too. You will feel the difference for sure.
Mank thanks for the suggestion. I will try it.
@zohaibakhtar1; @RehanBhatti
I have Cultus model 2010. I have put some jumbolon underlay (that thing which we put under the carpets in homes) between its roof / ceiling now heat doesnt come from the roof but still Cultus AC is not very powerful
Jumbolon is not bad idea. But you need multiflow condenser and evap to get good performance from your AC system. I recently changed my OEM crankshaft pulley(for water body & compressor) to G16B engine pulley. It is almost quarter an inch bigger in diameter on compressor side. Now AC is chilling more on idle and running as well.
I am also feeling slow acceleration when AC is On....do i need clutch overhaul?.I m still concerned fr tht smoke on start up....will it consume oil?
