Asalam o Alaikum,
Friends I again need your suggestion regarding my problem child, Cultus 2014. From last one moth, my car throw coolant from Raidator to Reservoir bottle on driving some 15-20 Km with AC and radiator becomes empty. My car is on direct fan with no thermostat valve. Heat gauge dont cross middle and performance of car remain fine. I have already changed gaskit and faced head from local market 5 months back and radiator is also new. There is no oil n coolant mixing, no heat up, no cream on oil cap & radiator cap is also changed to original one. Car is not reducing oil and giving no smoke. However, water level remains normal if I drive car without ac or in night time.
I went to local mechanic, they said radiator is fine but its gaskit issue. Head will be faced again. Gave estimates of 6000 with spares.
Then I went to 3S, on first impression they said you have gaskit issue and if needed head will be also faced. They gave estimate of some 10-15K. But when I asked that no symptoms of gaskit issues, are you sure regarding your diagnosis. Then they told me to come back on monday again, they will check it some other way which will 100% sort the problem.
I need your expert opinion or suggestion regarding the issue.
