kabli is hit and trial.... try your luck...
Can you share here about him?Im from isb
No need to spend 10 to 12k on plug wiresGet kabli wires in good condition they will work as new ones and will last long...
I got kabli cables for 800rs its been 4 years and they are still working excellent.Those ultima ones after 8 months started to make problems and missing, powerloss on full throttle.
Kabli ones are not more than 1k...
Depends on condition.
Any other good wires that must last 2 to 3 years
You can go to Zahid sb in I10 Auto Market. His contact details are 03335112238.
You can use my reference (hasnain) and can discuss with me any issue accordingly as well. my contact is 03335120067.
12 lacks
Can anyone tell me what sensor is behind exhaust manifold probably placed into cylinder block. I can see wire coming from there connects to Factory wiring.
That is engine oil gauge. And that wire control engine oil light in instrument cluster.
Thanks man.
Hi, i've recently bought Cultus VXRI 2010 and being the first car i am having little knowledge. After purchasing i replaced Engine oil , filter etc. I was not knowing which engine oil was being used and due my litl knowledge the oil changer( Though reputable) replaced it with Zic A+. ODO meter of the car is 54k( don't know its 154k or ?) but engine is in very good condition.My question is should i just stick to Zic A+( 5W-20) or some higher value. I've consulted shell company oil changer and the guy was saying that u should switch to 5W-30 and after some time then move to 10W-40. Guideline required, please.
Efi cultus recommended engine oil is 10w40 API SJ but you can use API SL too.
You mean fastest among whatsoever available in Pakistan (as a stock) ?
Yes.
What oils are you people using?
If alot of people are using the same stuff, we can do a group purchase of oil and filters, that way, we may save some money.
I was thinking of getting Vic filters from Karachi
Using zic x7 10w 40 and guard air and oil filter.
Maddy, please share current pictures of this cultus....
SGO Premium and Guard Oil + Air filter.
