Hi All.... Suzuki Cultus 2015 mileage 56562 km clr white registeration lahore city alloy wheels installed condition excellent total genuine car ist honour used..... plz recommend the price i want to buy it i have no idea for suzuki
Sorry. No idea about car prices
Koi aur he bta de cultus ka shokeen bhai
Kixx 10w40 API SJ, oil is highly recommended. I was using Suzuki oil, with this oil engine noise considerably reduced. I can see engine rev more happily.
Whats the demand of the person selling?
Has anyone tried liqui moly motor oil saver for those pesky valve seals my cultus smokes on cold starts or do you guys recommend any other oil additives to cure shrunken or cracked valve stem seals
Rs.1,100,000/- at-least.
Can anyone review about ultima plug leads are they any good compare to stock because my stock wire's are almost giving up.
ultima is fine but short life. but then again they are cheap.
not as great as oem but okay ish
Why not caltex havoline? Pretty good and readily available. And may I suggest you use 10w30 if you don't have oil reduction issue. It's even better, it will improve mileage as well.
Because we need old grade for this 80s engine. 10w40 is enough, I am not going for 10w30 in this as theire is very little reduction in 10w40.
Any Idea how much OEam one's gonna cost.
bro car turns off on its own as a safety mechanism if in case its getting heat up.
check your car engine cooling system accordingly.
ultima is the most farigh chinese brand. try and procure kabli stock cables they r the best and last a life time.
if you are in ISB i can recommend a very good mechanic for all cultus related stuff.
amazon delivers in pakistan?
i think 10-12k , call mumtaz autos for a quote.
I think ngk ones are a good idea, if you can arrange from amazon
sometimes, but it is never a good idea to get it delivered here, better to deliver to some friend and have them bring it when they visit PK.
I got quote for kabuli one for 5000 guy said these are slightly used and also were looking good in appearance. BTW 10 to 12k is too much because already spent so much on timing belt and bearing.
