Salaam all PWs, i want some suggestions regarding gear oil for Suzuki cultus efi.
Any of you changed it? Which company and grade is best for gear oil?
How much is used in cultus?
Your suggestions will be valuable for me.
There is no need to change the manual transmission oil unless it got contaminated by any foreign matter,just top up if u found its level down,i think cultus gear oil capacity is around 2.5 Ltrs,get it conformed from owner's manual.
Its 2.5 liter, i used ZIC , its best.
Change at around 30 to 40k intervals depending upon driving conditions
according to the manual we shuld change it at 40k and i changed it at 40k and used the recomended one from MINI MOTORS........
Which brand is recomended by Suzuki?
@scorpion1983
thanks brother,
which grade you used in ZIC GL-4 SAE 75W-85 or GL 4 75W-90?
have you any idea about cost of 1 litre zic Transmission oil in rwp/isb ?
zic is best
Nd new cultus me bhi 2.5 litr gear oil dlta hy brother?
Can any tell me which grade of gear oil is mentioned in manual for cultus efi
