Hi brother, Suzuki charging too much , follow my instructions im sure you can fixed by own . First of all check what is error code , usually codes came up belonging to air bag cob assembly or sensors usually installed right left towards fender ,you may also have more in door location.
testing method ;
First of all you must disconnect the battery terminal before testing srs. Remove the sensor harness and check the continuity by ohm meter it’s should be 1.4 to 1.5 kilo ohms , if no resistance replace it by purchasing kabli or new one ,
Next also check cob coil be removing airbag on steering, cob should have continuity in both connector, if you horn is also not working that make sure issue in cob coil
If everything is fine then it must be wiring issues or bad connectivity
