I was having problem with Oil leak from my engine for some time and it got worse with the passing moments, I finally decided to get rid of the problem and make some renewals and cleaning under my car's hood. So I went to the workshop where the mechanic uninstalled the engine and changed all the seals, cleaned the engine with kerosene oil and put new packing for the oil chamber and checked for any other leaks.
The gear box was also opened, cleaned and new clutch-barring was installed, now the clutch feels way better and softer than before and gears are easy to change, previously the clutch got very stiff and had to push it full to the wall to put the car into gear.
Also got new clutch-plate installed, sorry, couldn't get the pictures of it. It was a DK - Exedy clutch plate for FX, which I previously had installed 2.5 years ago, it wore out because of all home drivers learning on this car and harsh, rough and in-experienced driving.
now the car is performing better.
List of Items installed and Cost:
The cost of items is mentioned where I remember or can read the writing on the receipt of parts shop. The currency here is Pakistan Rupee (PKR)
2 Timing Seals Cost: 325
Main Oil Seal
Chamber Packing Cost: 225
Oil Pump Packing
Main Plate Packing
Upper Hose Pipe
Clutch Barring Cost: 530
2 Lower Engine Foundations: Cost: 440
2 Axle Seals Cost: 250
Clutch Plate - DK: Exedy Cost: 1600
Total Parts Cost: 1900 + 1600 = 3500
Labor Cost:
Clutch Plate Facing: 200
Mechanic / Workshop: 2500
Total Labor Cost: 2700
TOTAL COST: 6200/- PKR
