Hi there,
My GD110S got old but served me very well. Now is the time to change tires. Please if someone can tell
Tubeless Vs Tubed tires (difference is performance and life)?
which brand tires?
Tire size, real wheel original 2.75 X 17" I used 3.0 X 17" ( cg 125 size) It increased pickup and run smooth. now finished life. Is is ok to use this size in rear wheel?
Alloy rim, rear wheel got a little bent, . Some people recommend do not heat rim. where to repair in karachi?
Brake shoes. Original suzuki set is quite expensive. local dealers brakes do not work well. finished in 6 months. Are they same size as in Honda 70, because I think they are less expensive?
