SUZUKI THUNDER 125, the bike that should have been launched by Pak Suzuki, its far better than GD110 and GS150, and price is also reasonable than GS 150.
Engine
Type : 4
stroke, SOHC
Number of Cylinders : 1 (one)
Cylinder diameter : 57 mm
Step
Piston : 48.8 mm
Cylinder capacity
: 125 cc
Maximum power : 11.28Ps / 9,000 rpm
Maximum Torque
: 9.4 Nm / 7,500 rpm
Dimensions
Overall length
: 1,970 mm
Overall Width
: 745 mm
Overall height
: 1,045 mm
As Distance
Between Wheels : 1270 mm
Distance machine to Land : 165 mm
Empty weight
: 130 kg
Frame:
Brakes Front
/ Rear Brakes : hydraulic disc /
Drum
Front Tire Size : 80/90-18 M / C 45P
Rear Tire Size : 90/90-18 M / C 51P
Transmission:
Transmission
: 5 Acceleration
Transmission Type : 1-N-2-3-4-5
