I am facing this issue in routine that when ever GD hits any thing from side, its Foot brake lever bends. And I ever restore it by hand.
The reason is the material used for pedal/lever is too lite.
I know this issues is faced by most of GD users. So I am here to get and give suggestions and solutions.
Solution # 1: weld solid iron rod with the bend of lever.
Suggestions (need): which type of rod? how to weld?
Solutions # 2: find some other motorcycle brake lever.
Suggestion (need): which lever better fit in GD.
Solution # 3: make similar but solid iron welded lever.
Suggestion (need): please suggest...
