sir how much you paid for these led's and what about there output at night?
Yes they fit in original holders.
120 for three of them, in the day time better than bulbs.
and at night feels more bright, thats why kept bulb in the hi beam indicator.
@basicBrother, How was battery serviced? Like simple water level checking and greasing terminals etc.?
Sent from my Galaxy Nexus using Xparent Blue Tapatalk 2
Now that is what called proper tuning of bike MashAllah excellent sir you are complete mechanic of bike and its really nice to see that as foolish mechanic play with our machines & ruin them its much better if you are yourself trained & have enough knowledge to maintain your bike but not every one can adjust tappets of bike as this needs some training & learning but one can easily maintain his bike by keeping clean filters & changing oil on proper timing and also maintaining it like new by keeping it neat & clean
Sir i am very pleased for you that you have very good knowledge of bike & its great to have member like you here in Pakwheels bikers seciton with very good knowledge about bikes Basic sir one request can you kindly share some pics of tool that you used for tappet adjustment that tool seems great tool for tappet adjustment
@amjad635 the tool used to check tappets clearance is called feeler guage and can be purchased from any renowned hardware store
Syed Moazzam brother i am asking regarding the tool that Basic used for adjusting tappetsyes feeler gauge is also one of tool used for checking tappet clearance but i am asking regarding tool that he used to adjust tappet screw
@basic sirwhy so early spark plug change???
Well for that you need a Chaabi with round end tighten/loosen lock nut and to adjust the screw a simple screw driverIts that easy
can we use it on air filter???
Washing exterior, Water leveling, Greasing terminals .
As mentioned in the manual use special tool for lock nut for the tappets.
I don't have that, so for front exhaust used "L" shaped socket type, and for intake tappet used ring spanner.
Have to use both for tight spaces.
To feel and get better performance.
and Yes it worked.
thank you Basic for sharing pics
Basic that 10mm L spanner is it available in market? i have seen l shaped spanners but the tool that you have has hole means you can access tappet adjuster nut means adjust & tight lock nut at same time am i right sir?
@basic sir how often u adjust tappets of ur GS and till now, how many kms ur bike has driven and how many times did u adjust these??
Different markets have different stuff according to market demand.
For hole , yes you are right.
This is my first time on this bike.
I feel soooooo blessed to have met Basic Sir personally and that too by luck (H)MashAllah, your GS-150 is lucky to have an owner so careful like you, much better than normal Dealerships and so called ' Mechanics '.
@faiz.aslam.121
That was really a pleasant surprise for me too.
Thanks for your comments.
God bless you.
Chain lube. Saw it at a workshop. Don't know about price or availability.
Yar please tell me where did you see it?And please tell me about the priceThis is Maxima chain wax and the best chain lube out there in the worldkia discovery kar di hay ap nay yar maza a gya
