Still using Lm 20-50???
Sent from Mars
Yes, with 2% mos2.
Wat millage u get... As we r using LM10-40 mos2 ... And it runs around 3500-4000 easily...
That is really a good range, how do you judge now is the time to replace oil?
Replaced mine after about 2 to 2.5 k kms.
Felt a little noisy after 2k kms.
Engine gets noisy after 3.5k to 4k dats where we change it...
Right now i am 3300 and i have done extensive 1385km tour to Neelam Valley till Taubutt and came bk... But engine sound is unchanged... But will change it at 3500
Point of asking.... Why u changed from Lm10-40mos2 to LM20-50 mos2
Only used LM 20w50, no change till now.
Detail of 6th oil change. clock 07628 kms.
LM 20w50 plus 2% MOS2.
Oil filter replaced, air cleaner serviced.
7th oil change at 09566 kms.
LM 20w50 with 2% MOS2.
Air cleaner serviced.
Also new plug denso U24ESR-N SGP (from suzuki parts dealer) replaced at 10500 kms.
I feel vibrations in footrest and handle bar above 5k RPM (vibration like in cg125) below 5k it is very smooth and soundless. Is it normal?Mileage is 2500 km only.
Front fork oil replaced from local suzuki work shop.
130 ml in each leg, hydraulic oil as described in this thread and this post too.
And yes for experimental purpose added 5% MOS2.
Around a year and 10k km used oil from the front forks.
Check ur Tappiet setting and Timing Chain setting...
Nadeem Bahi, from where I can this measuring jug ??
This is quite common. I got one from a sunday market that dealt in kitchen ware
@basicNadeem Sahab what is the benefit of MoS2?
I converted all images of Suzuki gs150 Workshop manual into pdf file if anyone want to download the manual here is the link
https://drive.google.com/open?id=0B-q7o6EQVcKiaFRaWjY4ek9NbWc&authuser=0
Thanks Dr.mohsin
Nice and informative thread. Nice work Nadeem bhai.
