Salaam everyone
i need specs of valve clearance / tappet settings for the suzuki gs150se, plus whether to adjust them cold or hot. any guidance will be appreciated
thanksOsama
Answer to your question
wow that is great
does it mention anywhere to set them cold or hot
thanks
UPDATE
settings worked well
wow that was quick
Science 1 , andaza adjustment 0
to add to the spice, carburetor mixture was adjusted with a vacuum gauge
Bro you have to set valve clearance on dead cold engine...Exhaust valve clearance is 0.13mm & Intake valve will be on at 0.07+mm...how much kilometers your bike has done untill now??
1100 kms
already set valve clearances to 0.06mm IN and 0.15mm EX - running nicely
Ex valve don,t demand any kind of change...by increasing its gap bike starts vibrating on high rpms & you will feel these vibrations in footrests+its struggles at lot more
mine is more peppy now, good throttle response and no vibrations.. a little clicky tappet sound but thats normal
this vibration has something to with the model. no vibrations in model prior 2009 and vibration in later models?
i have a 2018 one, it used to vibrate before this adjustment, significant reduction post adjustment noticed
i need full page pdf please send me the link service manual engine
Search it in pakwheels searching you will get
i agree with you but inlet 0.008inch is good because 150 has high compression ratio
