- My speedometer is not stable (it waves too much), even if I have replaced the cable, & mechanics say it is bolted perfectly in the meter cluster. what is the solution?
The needle unstability is mostly caused due to the speedometer cable but since you got it replaced and checked then it could be a fault in the speedometer,
Kindly get your car,s speedometer checked.
- The temperature gauge is not working properly, I have changed the thermostat in the engine bay, still it hardly rises to quarter of an inch. The internal gauge is working properly as we have tested the cable which connects to sensor in engine bay, touching it to Hot areas, it shoots up the internal gauge. I still don't have proper idea of my car's temperature. What is the solution?
I dont know where is this temperature gauge connected in the engine bay to record the remperature so cannt say.
- The steering has become very light, after Camber setting, but it wobbles the steering on the bumpy roads, & tires feel detached as they move the direction of the steering wheels half a inch on every bump. What is the solution.
Your steering needs attention,
Does it creates a "khar khar" sound on bumpy roads?
