SUZUKI SA-310 (KHYBER)
DIMENSIONS
Overall Length: 3770mm (148.4 in)
Overall Width: 1530mm (60.2 in)
Overall height: 1350mm (53.1 in)
Wheelbase: 2345mm (92.3i n)
Tread (Front): 1335mm (51.2 in)
Tread (Rear): 1300mm (51.2 in)
Ground Clearance: 180mm (7.1 in)
WEIGHT
Curb Weight: 690 kg (1,521 lbs) ... 5 Door
Gross Vehicle Weight Rating: 1,180 kg (2,601 lbs) ... 5 Door
Max Seating Capacity: 5 persons
ENGINE
Type: Four stroke cycle water-cooled
No of cylinders: 3
Lubrication system: wet sump
Bore: 74.0mm (2.91 in)
Stroke: 77.0mm (3.03 in)
Piston displacement: 993 cm''' (60.6 cu.in)
Compression Ratio: 8.8 : 1
Carburetor: AISAN two barrel down draft
Air cleaner: Dry type polyster fiber element
ELECTRICAL
Iginition timing: 4" B.T.D.C. at 800r/min ..... Manual Transmission
Standars Spark Plugs: NGK BP6ES or NIPPON DENSO W16 EX-U
Battery: 12V 1101 kC (28 Ah) 5 HR
Starter: Magnetic Shift Type
Generator: Alternator
TRANSMISSION
Manual Transmission:
Clutch type: Dry Single Disc
Transmission Type: 5-Forward all synchromesh, 1 reverse
Final reduction Ratio: 4.105
Gear ratios,
1st: 3.416
2nd: 1.894
3rd: 1.280
4th: 0.914
5th: 0.757
Reverse: 2.916
WHEEL AND SUSPENSION
Tire Size Front and Rear: 145 SR12 or 5-95-12- 4PR
Tire Presure:
Front: 220 kpa/31 psi ..... 145 SR 12
Rear: 220 kpa/31 psi ..... 145 SR 12
Suspension type:
Front: Strut
Rear: Torsion Beam
STEERING
Turning Radius: 4.7m (15.4 ft)
steering Gear Box: Rack and Pinion
BRAKE SYSTEM
Type: 4-wheel, hydraulic
Wheel Brake:
Front: Disk Brake (floating caliper type)
Rear: Drum Brake (leading and trailing)
Parking/Handbrake: Mechanical, acuted on rear wheel
CAPACITIES
Cooling Solution: 4.3 L (9.1/7.6 US/lmp pt)
Fuel Tank: 33L (8.7/7.3 US/lmp pt)
Engine Oil: 3.5L (7.4/6.2 US/lmp pt)
Manual Transmission Oil: 2.3L (4.9/4.0 US/lmp pt)
