Yes, you can carry on with ZIC if you are satisfied.
For flushing, drain the radiator and remove the thermostat valve and use your garden hose to remove all the coolant in lines.
Thermostat valve is a barrier for coolant between engine and radiator. So if you just drain the radiator, the coolant in the engine lines will still be there.
