I have suzuki mehran 2008 model, after 2500km drive oil remained only 1liter. My car exhaust is clear without any smoke. Also oil that i changed before it was havoline motor oil. Also No oil leakage detected.Need suggestions for root cause
Please tell ur city so seniors can guide. That much oil being burned by engine should be checked by doing a Compression Test. Worn out rings/valve seals may be the culprit but these have prominent bluish/startup white smoke from exhaust.
Black smoke comes from exhaust at 1st startup in morning, may b because of choke pulling
Black smoke is due to rich fuel.Do compression test to get real idea of your car engine's health.
Where can i perform compression test in lahore?
@capsat @syncview
Check pcv valve... it would be blocked.
