Well it appears to be wheel bearing, but verify it by lifting the wheel using a jack and check wheel movement.
Check by rotating the wheel, and also check for a bad hub (play)
This should give you a better idea
Its usually hard to feel the sound due to wind noise when you lean out of the moving car. To verify just follow the video. Make sure to check all tyres as its usually a bit hard to pin point the exact wheel inside the cabin.
